RCU Forums - View Single Post - 3W 150QS starting problems
Old 06-21-2005 | 08:20 AM
PlaneInsane
Default RE: 3W 150QS starting problems
Sounds like you need to check the sealing on everything from the reed block housing down to the carb block. And make sure your Ryton block isn't cracked somewhere. You'll have to look close to see if it is. As a general rule if you see wetness on the sides of the reed block assembly you more than likely have a leak. Everything should be nice and dry.
Rich
