RE: Compression Testing a 50cc engine ?
I used the standard Sears automotive comp tester and just fliped the prop as hard and fast as I could until the reading stopped increasing.....It maxxed out at 110 PSI....not bad for hand flipping.
As long as I repeat the same technique using the same tester I think it should provide comparitive readings over time.....we'll see.
