RE: PCM or FM RX on an electronic iginition engine?
Well I put the PCM Rx in the plane and went to fly it, but found a problem with the wing that grounds it temporary. Anyway, I range checked it with the engine running, plane on the ground, and the receiver flat on its back on the ground, it range checked at 200'. Definitely better than with the PPM receiver. I will know more after flying it tomorrow.
Chuck
