What does it mean to.....
Valve float occurs when the spring pressure can no longer overcome the inertia of the entire system. It has to accelerate the valve, rocker arm, pushrod and cam follower fast enough to keep everything in contact. When you have excessive floating the valve is no longer where it should be compared to the piston that's hurtling up the bore towards it and it's possible for the piston to hit the valve. Not good!
