RCU Forums - View Single Post - Pattern plane conversion
Old 06-22-2005 | 08:54 AM
PatternPilot's Avatar
PatternPilot
My Feedback: (58)
Default RE: Pattern plane conversion
Well the normal CC or Jetti controller can not handle the amount of volts.. This is the NEW HV 110 amp controller max input volt is 50 and I'm hitting 42 volts at the start of the flight.. The unit is absolutly cool to the touch after landing. There was testing done with the Jetti 77 and we had a burning plane upon landing.. The new Jetti 90 might have worked but ever since my friends plane landed with flames I wanted to stay with CC.
That AXI max amp rating is 75 from what I was told.. I'm pulling 69 amps and doing 2200 watts ... better than 200 watts/lbs turnnig 6250 rpm on a APC 18x12 E prop..
Scott Anderson
NSRCA 529 D-3 AVP
