RE: Brison 4.2 loading up on the down lines
Hello Big Bird,
Thanks, I am about as lean as I can be on the low end.. it will die in the transition if I go any more.. I blocked off the scale inlets and that has cured the pull up isses but the engine is still ragged at the lower throttle settings.
Thanks agian and enyoy your day..
