ORIGINAL: up_in_smoke
can any one help i need to know is there any way i can replace the rear bearings as there is nearly 2/3 ml of movement in my mamba 8000kv motor thanks in advance
The case is sealed so you would need something to re-seal it even if you took it apart unlike some of the other brushless motors that simply unscrew apart. You're probably better off to return it to Castle Creations, but I would send them an email along with purchase information prior to shipping.
