RE: Split Elevator Trimming
If you guys are worried about the equalizer or matchbox being another point of failure - DONT! They are bullet proof. I use them on the largest and most expensive planes and have never heard of even one failure from anyone. If you want true symmetry it really is the only way to get it. If you don't mind differentials then keep going the path of 2 channels.
It makes life extremely easy as well. You will be done with the whole issue literally in 5 minutes AND the setup will still work if you change transmitters.
DP
