RCU Forums - View Single Post - OS FS-91 under-powered.
Old 06-23-2005 | 01:46 AM
SolarWinds
Default RE: OS FS-91 under-powered.
Thanks, BAX,
The fact is that I have not seen rpm more than 9000 with any prop, so something is wrong. Since fuel system is ok (fuel, tank, fuel lines...) the problem must be in the engine itself. What is your opinion? What should I check? compression, valve clearence?
Thanks again,
Yannis
