RCU Forums - View Single Post - metal to metal contact causing interference question
Old 06-23-2005 | 07:14 AM
CGRetired's Avatar
CGRetired
Default RE: metal to metal contact causing interference question
It's not the friction that causes the problem it's the metal to metal vibration that causes the problems such as metal pushrods on a metal carb link arm. Also, problems can be created with metal pushrods that run parallel to the antenna within the fuselage behind the servo's.
