RE: GMS Engine Tuning Problem
So why would the high speed needle be causing the problem? Are these known to be bad? I did check and clean the entire fuel path from the tank to the carb. I found no clogs anywhere. I suppose I could throw on some other needle to see what happens. On the engine my son has, the needle was very insensitive, and needed to be open more than I thought it should be.
