RCU Forums - View Single Post - metal to metal contact causing interference question
Old 06-23-2005 | 01:45 PM
bubbagates's Avatar
bubbagates
My Feedback: (32)
Default RE: metal to metal contact causing interference question
ORIGINAL: Pilot Chad
i have a metal control horn that i had to drill out the nylon part, and i have the metal pushrod going through because i am using and L bend, will this be a problem?
We are talking about metal to metal contact, you are describing using a metal to metal contact, so I would say yes, this can be a problem once it starts to work loose and it will start to work loose from normal vibrations. It may be on a small plane but why would you risk it.
