YS63 air bubble problem
The bubbles are normal. If the engine is running OK, ignore them.
The regulator controls the transition from low to high throttle. If it was running OK why did you change it? The flush with the casting setting is just the recommended starting point for setting the reg.
Good Flying,
Dave
