RE: What caused this flame out?????????
What engines are you using? When you 'checked everything' did you check for garbage in the needle valve of the problem engine? As it takes only a small amount of crud to block things up a small particle may be floating around causing some grief. Do you use fuel filters? I use Sullivan 'Crap Traps' just before the needles on my B-29. If I have to adjust them more than a couple of clicks each way the first think I look for is crud in the needle valves. - John
