RE: receiver problems?
Just because you have good voltage, and most of test it static, doesn't mean you have enough power to run a system. If you are low on amperage then you may not have enough to serve all. Also when we are flying the control surfaces have to work against the wind, centrifugal forces, and gravity. A static test that gives you say 4.9 volts may dorp when pushing surfaces loaded in flight.
