RE: receiver problems?
Even so, a voltwatch will flicker and the display will change if you simply move several surfaces at a time or if you "load" a surface by applying pressure on something, like he said, it isn't a battery issue here, It sounds like the receiver is bad, and your best bet it to go for a new one. Good luck, get back on the sticks...
