RCU Forums - View Single Post - Retrack Servo Help
Old 06-25-2005 | 01:02 PM
Richard L.'s Avatar
Richard L.
My Feedback: (24)
Default RE: Retrack Servo Help
Retract servos do not response to EPA on the transmitter. You must reduce the throw mechanically. The distance between the two EZ connectors on the servo arm must equal the distance that the retract actuator rod moves from lock to lock. Try to find a smaller servo arm. New holes can be drilled on the servo arm if necessary to get the correct throw.
