RCU Forums - View Single Post - Sig SE wings?
Old 06-25-2005 | 07:32 PM
windtalker's Avatar
windtalker
Default RE: Sig SE wings?
Wild-Willy, why couldn't I cut the tube in half, and reduce the length some.
Epoxy each of the two tubes permenantly into the wings,,, Then drill two holes thru both wing tubes inside the fuselage and use the plastic bolt/pin method to hold each to the Phenolic Tube???? Maybe turn the pins up instead of the way I have it drawn.
