RCU Forums - View Single Post - CG For Somethin
Old 06-25-2005 | 07:44 PM
windtalker's Avatar
windtalker
Default RE: CG For Somethin
Let me know how it does.... This kit seems to be one of the most bashed kits out there, besides the 4*. Think the next bash I will do is to eliminate some of the wing tube. (Also discussed in another forum. Q&A i think) I can not see the need for so much tube.
Either cut it into 2 pieces and permenantly install into each wing, or just cut some off each end. Then add foam to the ends to prevent shifting. My tube moves around a bit causing vibration. I have added some foam to each tube already.
