RCU Forums - View Single Post - Poulan 25 from FL trimmer
Old 06-25-2005 | 09:21 PM
  #34
RysiuM's Avatar
RysiuM
Default RE: Poulan 25 from FL trimmer
ORIGINAL: flipflop
How did you modify the stock carb to adjust the needles?
I didn't. I cut the plate under the needles (the original guide, that helps adjust the needles on weed whacker) as it interfered with throttle linkage. This was the only mod to the carburetor.
For adjusting needles while engine is running I made a simple tool: U-bent 7/32 aluminum tube, that the end I pressed to the mixture adjusting screws to shape the 'grabbing' part. It was not a rocket science
See pictures below of the tool and the engine. My home made test stand works OK as long as someone holds it from the back. I also show throttle linkage - easy and clean solution. Details of modified muffler and finally the magneto strike.
Enjoy
RysiuM
ID:	289746   Click image for larger version
ID:	289747   Click image for larger version
ID:	289748   Click image for larger version
ID:	289749   Click image for larger version
ID:	289750   Click image for larger version
ID:	289751   Click image for larger version
ID:	289752   Click image for larger version
