RE: FLUTTER problems flying the "U Can Do 3D"
Couple of suggestions. Seal the hinge line on the elavator with some clear packing tape. And replace the push rods if you feel they are to weak.
Try a higher torgue servo if you can get one. Yours looks like a standard one that comes with the radio.
Also go with a 12x4 or 13x4 prop. The 11x5 can still generate to much speed even at lower throttle settings.
Good luck and have fun !!!
