RCU Forums - View Single Post - Cold Duck - Build
Old 06-26-2005 | 10:41 AM
8178's Avatar
8178
My Feedback: (17)
Default RE: Cold Duck - Build
I like to complete the setup of the engine mount, fuel tank and nose gear steering before the firewall is installed. It is a lot easer to drill holes and mount stuff with the firewall on the bench. Many years of building Howard Engineering kits has influenced the way I build, so I’ll be borrowing his well engineered fuel tank mounting system for the Cold Duck. See my Howard Engineering Kwik Fli III build on RCU at http://www.rcuniverse.com/forum/m_2434444/tm.htm
A plywood plate is made for the front of the fuel tank that bolts to the firewall with blind nuts. It is a really neat system and keeps the fuel lines from getting kinked and makes tank installation and removal easy. I’m using the specified Sullivan RST-12 fuel tank.
I decided to mount the engine less than the original 90 degrees for a little more muffler clearance.
ID:	289921   Click image for larger version
ID:	289922   Click image for larger version
ID:	289923   Click image for larger version
ID:	289924   Click image for larger version
ID:	289925   Click image for larger version
ID:	289926   Click image for larger version
ID:	289927   Click image for larger version
