RCU Forums - View Single Post - FLUTTER problems flying the "U Can Do 3D"
Old 06-26-2005 | 01:34 PM
Tall Paul
Default RE: FLUTTER problems flying the "U Can Do 3D"
The pushrod is too close to the surface.
Move it out to the last hole on the horn.
When you want more surface deflection, make the control arm on the servo longer.
You should be using the longest arm that comes with the servo anyway.
