RCU Forums - View Single Post - Tips to save your airplane
Old 10-11-2002 | 08:22 PM
Unstable
Default Tips to save your airplane
another tip to save airplanes.
if you are in a spin, loose orientation, whatever.
level the airplane first, get it going in the right direction second.
I have seen alot of crashes do to people that have got confused and saw the airplane was going the wrong way so they tried to turn before they had the plane level and in control. they end up banking it into the ground or something similar.
even if the plane is going over the flight line GET IT LEVEL.
I would much rather see a in control level plane over fly the pits than a out of control plane spin in front of the pits.
also if you come out of somthing inverted.. you can keep it inverted until you have altitude to recover.
how many people have seen a plane go in because it was inverted too low when the pilot tried to roll it.
level is level, upsidedown or not.
here is a few links of what im talking about.
First how not to do it.
second how to do it.
notice on the second he overflew the pits (still bad) but kept it level and climbed out over the trees were the first he fought to direction right into the tree.
