RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND FASTER!!!
Just wondering what servo you gonna use on the elevators? They operate sooo smooth and are basically counter-balanced when installed, really impressive. I know there will be a little more load on them in flight with the whole stab moving so I wanted to put a HD servo. I tried 2 seperate digital servos and both glitch slightly when operating. Maybe all the metal, not sure. So, I put a carbonite geared heavy duty Hitec servo there. The issue is the torque. How much is enough here? This particular servo has the normal 42oz of torque. Is anyone using a standard servo on the elevator? Thanks for the info.
