RCU Forums - View Single Post - Poulan 25 from FL trimmer
Old 06-27-2005 | 12:56 PM
  #37
RysiuM's Avatar
RysiuM
Default RE: Poulan 25 from FL trimmer
ORIGINAL: flipflop
removed each needle and cut a slot in them so I could just use a screwdriver to adjust the carb.
I thought about that, but then it would be impossible to adjust the carburator with engine running as needles are just behind the prop. With U-shaped tool I can reach the screws from behind and crown-type head allows the tool to engage at almost any angle for easy turning.
RysiuM
