ok i got the pics
the problem)the the washer doesn't take up the space need. and if the space isnt taken up it makes the wiggle witch isnt good.
the fix)
1) take one E clip off the hing pin and take one washer and set to side other do what u want we only need one
2) take some of your silicon fuel tubing and cut a little bigger with than the washer would take up
3) put the hing pin in and slide the fuel tubing over the pin then slide the knuckle and the original washer
4) reconnect E clip and reassemble and its done the wiggle is gone
if you need pic, or any more help please feel free to ask me or pm me this works
i want to here your comments
