RCU Forums - View Single Post - NEXSTAR ARF .....PROBLEMS...PROBLEMS
Old 06-27-2005 | 10:58 PM
red head
Default RE: NEXSTAR ARF .....PROBLEMS...PROBLEMS
ORIGINAL: wheels4009
Thanks for all the input......I know the front wheel is sensitive and am going to redo it. Seems after a few landings won't stay straight.
Dr1.....nice to hear others are having probs as well. I realize I am not considered a "pilot" yet......but this thing is ugly getting off the
ground......That thrust issue may have something there as well. I will def check into it.
Thanks again for all the input......Please don't mistake "sour grapes" here on my part and just wanting to blame the plane instead of
inexperience......having to use the rudder sooooo much at take off is messing me up.....bout half afraid I'm going to kill someone with
this thing taking off.
Thanks again for letting me VENT
In the first sentence you say it won't stay straight after a few landings. Is there a flat spot ground on the nose gear shaft for the set screw to lock into????? And toning the stearing down will probably cure most of your problem. You may also be using tooooo much control on the rudder. Hope something helps. ENJOY !!!! RED
