RCU Forums - View Single Post - mounting elevators on extra 300 LX
Old 06-28-2005 | 07:13 AM
mogley
Default mounting elevators on extra 300 LX
I'm just installing my elevators on my extra (one of two aircraft I'm building). The h-stab has two holes for two screws (4mm) per side to attach the stab to the fuse (the harwarde kit on both planes only supplies 2 bolts per plane). The instruction manual also states to use two bolts to secure the h-stab. If you read the instruction manual further and read the quick start quide it states:
5. The horizontal stab assembly mounts on one 1/2” aluminum tube. One 4mm
screw is used at each side to retain the stab assemblies. Use lock washers on
them. Put pins through the rear antirotation dowels to act as a backup to the
side screws.
The h-stab does not have a rear antirotation dowel, only in the front. How are you supposed to put a pin through this dowel? The only thing I can think of is gluing a bolt into the rear thread, cut off the head and drill a hole to accept a pin.
I really need the stab to be removable because I only have a durango and need to transport both planes to the field.
