How does the screw break off, Elvis? That would be helpful to know.
TEAMERICA, 15% Power master with 23% oil heli fuel was HORRABLE in my 50. It stank, smoked like a smoke bomb, and the mid end was as rich as eggnog! I had to nurse it like you did, if you can try some CP 15% in it, or maybe your home brew will work. I don't know about the glow plug but I spent hours messing with that power master. I know what you mean; I also cooked my high end to get the mid range even close.
I also had problems with Magnum 15%, I usually run CP 15% but will try some CP 30% soon, and I can't wait!
The CY muscle pipe I put on really helped the idle. Very low and reliable idle now. I know this sounds strange but the CY muscle pipe makes the engine easier to tune because you can hear the change better.
