RE: NEXSTAR ARF .....PROBLEMS...PROBLEMS
The "wing thing" (removing dihedral) is arguably the most important mod that you can do to this bird.
The easy way is to bend the steel rod, bit-by-bit, until the wing lays flat & then fill the central wedge-shaped gap with balsa wedges & Probond. Drill a hole in the LE for a 1/4" dowel & drill a new hole for the wing hold-down bolt (reinforced with a ftat plate of 1/16 ply) & away you go.
I prefer to cut into the end ribs & glue in a hardwood wing joiner against the mainspar, and add a 1/8 ply LE wing joiner up front. The gap is filled as noted above. This is more work, but it is lighter & a bit less flexible.
I always add dual aileron servos to a Nexstar wing mod -- this eliminates any chance of aileron flutter.
As noted by Winghawg1, the LE droops don't have any influence at all on take-off stability.
Another important & very easy mod, is to eliminate the right thrust & re-center the engine. I straighten the firewall with a balsa wedge, then cap it with a layer of 1/8 ply before re-mounting the engine dead center. In the case of a crash repair, I actually completely replace the firewall with a 1/2" thick ply piece, laminated up from layers of balsa & ply. I also pin the firewall from the sides with #4 screws.
