RE: Sr Falcon ARF
Thanks for the information on the dihedral for the Sr. Falcon. It is very helpful. Although I do maneuvers such as inverted cuban-8's, outside loops, inverted true spins and the like, I only fly around inverted when I want to torture myself, so I am going to go with the stock dihedral. I expect to use an OS Max .46AX since the FX is no longer available. Logitrol is a name I haven’t heard for decades. This plane certainly brings back memories. I think it was a Kraft reed set that I used in my Sr. Falcons.
I agree with you that the Sr. Falcon may well be an excellent trainer - - what I like, besides the nostalgia, is that it is a beautiful plane which does not look like a trainer and is capable of many maneuvers that a trainer can’t do. It should be a relaxing change from the Super Kwik Fli 90 and modified Super Kaos 60 I have been flying. Meanwhile, I am in the midst of building another Kwik Fli Mark III from scratch.
When I have the Sr. Falcon flying I’ll let you know how it goes with the stock format.
Thanks again.
