RCU Forums - View Single Post - LSP video
Thread: LSP video
Old 06-28-2005 | 01:40 PM
itspuddingtime00's Avatar
itspuddingtime00
Default RE: LSP video
Just a little tip for when you are jumping. Don't stay on the throttle when you are in the air, (correct me if I'm wrong but I noticed it a little bit). You should leave the jump then let go of the throttle, and while you are in the air, use the throttle/brake to control the truck. If you need to nose up a bit, then just blip the throttle. If you need to nose down a bit, then tap the brake.
