ORIGINAL: chasrb
I found this forum while looking for some info on my Brison 4.2 (gold). I too have a 1/3 Lainer Laser 200 that I bought and have stripped off all the bad covering. It's in decent shape, but I need to see some documentation on where things go. I have the downloaded pdf from Lanier, but since this is my first gasser I'd like to know where everything should go per mfg specs. Does anyone have details or other doc. for this plane? Did Lanier offer any pdf's of the plans?
Does anyone have photos of the setup they have in the plane?
hey chasrb,
What info are you looking for? The CG is on the tube,I believe they have the throws they recommend on their website..
I don't have the plane at my house,it's in my dads trailer so I cant take any pics yet..
The two rudder servos go into the bottom servo bay in the back of the fuse(one on either side of the fuse) and the elev. servos go into the top servo bay on either side of the fuse. I have my throttle servo in back of the firewall and my reciever and ignition batteries are in the turtle deck behind the cockpit mounted on a 1/4" piece of light ply.. the fuel tank is in front of the wingtube..
I hope this helps some!!!
Frank
