RE: Showtime
For your information: The tail wheel steering setup is impossible to do unless you have a 300 oz servo for the rudder. If you set it up like they say, the springs will put a large amount of pressure on the rudder servo at a full 45 degrees over. It will work just find if you set it up like the Hanger 9 Extra 260. You can go to Horizon Hobbies web site and look up the Hanger 9 Extra 260 and open the manual, you can see how they did it.
Pat
