RE: Extreme Flight Yak 68" E-Conversion, Advice needed
I would go with a Hacker regulator,,,
thinking this setup will give you good power, but you should prop it for maybe 50A max as you only have the 4000mAh packs... swinging a 22x12 prop.
13 or 14XL sounds about right.
