RCU Forums - View Single Post - *Modeltech Formula ARF 3D Competition 46-60*
Old 06-29-2005 | 02:18 PM
  #50
Xup's Avatar
Xup
Default RE: *Modeltech Formula ARF 3D Competition 46-60*
Zippy,
For the first flight, with the CG at 5 inch, only fly out half the tank, and see how you get on with her.(the half a tank left in her will keep the CG forward for you)
Set up dual rates with 50% expo, mainly on elevator as when you come off the throttle with a rear CG it will
rear up on you, if you fly the Tank dry you will need down elevator to land. (if it is like the first UK version)
what weight did if finish at ?
good luck m8
X
