ORIGINAL: jlchapman
Chasrb -- Give me a couple of days and I can post some pictures. Let me know what shots you want. Mine has been sitting for some time, so I'm doing kind of a rebuild. New tank, switches, fuel lines, update ign and motor, changing the placement of some equipment and replacing extensions. I built the Laser almost 10 years ago and the plane is in great shape. This was my first gasser and now I like to do some things different. Go ahead and post some pictures.
Frank -- You mount the ignition and rx battery together and you have no problems with interference? I always try to keep those two circuits as far apart as possible.
Jerry
Hey Jerry,
Yeah I have them mounted together I didnt notice any problems,but I think I may move them apart just in case. I'll have to move something else to help out my CG though.. I didnt think there would be a problem with the batteries next to each other. I do have the ignition far away from the reciever.
The first time I ran it up with the new motor I did have some interferance then had nothing because the reciever battery unplugged itself from tne reciever. I ended up using some silicone and a rubber band to make sure the rest of them stayed plugged..
I then had no more glitches..So I guess with the battery plug getting loose that was causing the interferance..
I just ordered a Bolly 24x10 from Aircraft International,should be in soon then Ill try that Sunday..
Later, Frank
