RE: Multiplex Evo and IPD technology?
I had an Evo 12... I sold it. Some features it was lacking that I wanted:
1. There is only one expo setting per surface per model. You can't change the expo with dual rates or flight modes.
2. There are no multi-point mixes... all of them are linear. I use multipoint for several things.
Other than that the radio was OK.
I still use the IPD RXs in my gas planes... I really like them. They get awesome range checks with my 10X... better than most other RX's I've used. Personally, I don't like PCM and will never use it again. I want to know I'm getting hit without my RX locking out. FWIW... I also use some plain old PPM RXs in a gas plane... they work great. You just have to set your plane up correctly to use them... you should really do that with PCM also... otherwise it just hides the problems until they big enough to bite you in the knickers.
I'm sure someone will disagree, but this is how I do things.
