RCU Forums - View Single Post - my tranny's slippin but it's not the slipper...?
Old 06-29-2005 | 05:17 PM
jakjr's Avatar
jakjr
My Feedback: (18)
Default RE: my tranny's slippin but it's not the slipper...?
ORIGINAL: usmcrc
I think that is part of my problem, the screw keeps backing off. It seemsto gradually slip more and more as I run it. I will try flip the rings...makes sense.
If the screw is coming loose you might want to check and see that the diff is in the tranny the right way. The adjustment screw should be on the right side of the car when veiwed from behind. If you put it in the other way itll come loose as you run it.
