RCU Forums - View Single Post - Pushrod system
Old 06-29-2005 | 06:00 PM
NJAIRSTRIKE
Default RE: Pushrod system
for some reason I find it easier to use a rod and inside it a wire going through it, if I go that route would it be okay? I'm not sure what a wood dowel is but this wood is not hollow, you have to dril la hole on both ends then have a rod bent going inside the hole to the servo and same to the other side.
Something like a Dubro Lazer Pushrod.
