RE: NEXSTAR ARF .....PROBLEMS...PROBLEMS
Britbat...I hear what you are saying about "inexperience".....can't argue that. But I along with others with alot more knowledge than me
believe there is something not right...........SO.......today, I changed the 2 1/2 " sponge tires to Dubro 5 1/2" rubber tires hoping for a
little better grass field take off control.........NEXT......I took out the front hear RE-flattened a little larger area with a new control arm and
also was able to raise the front gear about 1/4" hoping it will help with a little "quicker" lift off.
Again.....I AM LEARNING MORE EVERYDAY.....THANKS TO ALL OF YOU GUYS INPUT.
If this doesn't do it.....or at least make it "tolerable" I will look into the thrust issue.
