RE: Vectorflight Edge 540 build
Salty, your plane is comming along great!!! is that the 91fx? Im sure that will really make the plane sing. Have you thought up a way to mount your antenna? If i might add I tryed routing the wire inside the fuse to the back but, for some reason ive been getting a little bit of glitching at some distances. I then basicly routed the antenna on the outside on the bottom of the fuse and havn't had any problems. I took some of the extra covering VF provided and taped it to the bottom. It does get quite messy with a lot of flying but the covering is pretty tollerant with the oil mess.
I can add pics if needed.
Gary: Where did you end up putting your reciever and battery? I put my reciever right behind my tank on the bottom which is then held in by a scrap piece of balsa which i screwed in. I get kinda worried bout the TX being that close to the tank. But it works....
