RCU Forums - View Single Post - NEXSTAR ARF .....PROBLEMS...PROBLEMS
Old 06-30-2005 | 08:17 AM
  #49
britbrat
Default RE: NEXSTAR ARF .....PROBLEMS...PROBLEMS
ORIGINAL: Winghawg1
Britbat do those things really cause much difference in the way the plane fly's, guess I 'll take off mine and see.
The speed brakes are just that. Without them, the plane is noticeably faster & has a longer & flatter glide -- it floats more. With the brakes on, the descent is steep & slow -- great for spot landings, but really bad if you dead-stick any distance from the runway.
The wing cuffs also cut top speed, & not surprisingly, reduce landing speed -- it's quite a bit faster at full throttle & noticeably faster landing without them -- again a longer & flatter glide (still more float).
Both brakes & cuffs affect agility and seriously degrade inverted flight capability, although at that stage, students won't be doing anything needing serious agility & won't be flying inverted. With the brakes off, & the cuffs on, the Nexstar has reasonable inverted capability & is agile enough for simple aerobatics. With everything removed, the Nexstar is pretty fast for a trainer -- just about 70 MPH, and once the throws are cranked up it can do quite respectable aerobatics, including hovering, a wobbly knife-edge & outside loops.
The plane needs re-trimming when the bits are removed, but this is to be expected.
