RE: JetJoe OWNERS thread
Hello Paul,
I rate the JJ1400 10/10 and JJ1200 10/10. Not because i am a rep but because of actual testing. I have now 75 flights on JJ1400. Every motor i receive is test run and checked for problems before shipping to customer. I have not received a motor that is not working. (touch wood) Serial numbers starting from 614 and my latest batch is 700 +. Do not know about there accessories. They do not recommend their own pump. And i also heard that there is a problem with starter motor.
I use the Gaspar electronics only with hausl pump. I do not like auto start on any turbine and therefor all my motors are manual air start. More reliable and cooler on bearings. Just my opinion.
Any turbine is not a toy and if you do not know what you are doing things will go wrong very quickly. I must have been lucky so far or JJ is doing something right.
Regards
