RCU Forums - View Single Post - 9303 Programming Gyro Sense on a 6 channel Rx
Old 06-30-2005 | 11:39 AM
Fortune7
Default 9303 Programming Gyro Sense on a 6 channel Rx
Hi,
I'm setting up an electric mini heli with a JR 610UL (caseless) receiver and a rate / HH gyro with a sense function. My 9303 Heli TX recognizes Aux2 as the Gyro function, but I only have the Gear channel (5) spare (Aux2 would need a 7-channel Rx). How can I set up the gyro's sense funcion using the gear channel? Do I have to disable the Gyro sense function? Is there a mix I can use for Aux2 - Gear for the same result?
Appreciate any help you can give.
Andy
