RE: Saito 220 WOW!!
Miloh, Ultra rc just came out with a 29% giles that only weighs 10 1/2 lbs. with a Os 1.6. With the 220 you would probably have an 11lb. plane with 1100 sq. in. of wing. The trim scheme is pretty ''busy'' but by looking at the vidio in the 3D forum It looks like an awsome plane. It has a floating wing that you can adjust the C/G with without adding weight.
Marc 540
