RCU Forums - View Single Post - Extreme Flight Yak 68" E-Conversion, Advice needed
Old 07-01-2005 | 03:18 AM
luc-RCU
Default RE: Extreme Flight Yak 68" E-Conversion, Advice needed
disco:
If you can put your hands on TP prolite 2000, that will be much better as you could certainly put less cells in // (hence a lighter plane). The voltage under load is also excellent.
They are right now by far the best lipos on the market.
