Yes,as they all will either use a Walbro,Zama or Tillotson brand carburetor.They are all interchangeable providing you keep the venturi size comparable to one another.There might be problems related to position of throttle and choke levers and such as there are many different ways of actuating these devices and you might have to get a little creative to get them to work with your original set up your using.The largest venturi size you will want to use on that engine is around 11.1 mm.Any larger than that and your engine will start to experience transitioning problems.There is such a thing as "over sizing" the carb TOO much
.If you do a search for 11.1 mm carbs in this forum,you will come up with a wealth of information on the subject.
