RCU Forums - View Single Post - Heat and Humidity on Engine Performance
Old 07-01-2005 | 08:43 AM
cat250
Default Heat and Humidity on Engine Performance
Does high heat and humidity(95+F 100% H) have a negative impact on 2 cycle engine performance? Yesterday my engine seemed to be loading up on fuel after setting the throttle for relaxed cruise and then going to full power. The transition was not smooth. Leaning out the low speed needle improved things a bit but still did not get rid of the problem.
